stuck in 4wd
Old Oct 14, 2009 | 03:53 PM
mike3212's Avatar
mike3212 is on a distinguished road
Default stuck in 4wd
hello I have a 98 chevy blazer and have a problem with the actuator. There is a constant suction from the vacuum hose that hooks to the actuator and I was wondering if anyone knew why this is. Even when I have it in 2hi the actuator stays engaged from the vacuum suction. so I have to unhook the vacuum hose to release the cable.
Old Oct 14, 2009 | 05:59 PM
96Blazernut's Avatar
96Blazernut is an unknown quantity at this point
Go underneath your blazer and on top of the transfer case there is a vacuum transfer switch. More than likely its stuck in the 4wd position. you can replace it with one from Autozone for less than $20.00 That was what was wrong with mine. Its just above the front driveshaft on the drivers side. It has 3 hoses connected to it. This little vacuum switch tells the front axle when to engage.
I had the same problem on my 96.
Old Oct 18, 2009 | 06:21 PM
86Blazer4x4's Avatar
86Blazer4x4 is an unknown quantity at this point
did you have the floor shifter on yours? im having something similar the front axle on mine is locked up and i can physically shift it into 2 wheel drive but the transfer case is still in fourwheel drive.
stingray74
Mar 5, 2015 08:27 PM
mr.vls
May 4, 2013 03:45 AM
Havensk
Jul 25, 2010 08:16 PM
aspenrebel
Dec 12, 2007 05:52 PM
bcmaxx
May 8, 2006 06:59 PM
