stuck key and shifting issues
im havin same issue, but if i push the lil button on the the colum by the key. the key moves to lock, but the shift problem would still be there. i reset the pcm (more than once) it will start in 1st gear. mine says a low voltage code was present. i checked all fuses, it has a new ingtion switch, and the neutral safety switch is working, if u dont press on the brake it will not move out of park, so thats workin, ive checked the plug at the trans its tight, checked the pcm plugs they are tight, just hope we can figure this out, please help if u can thanks
my truck had a old o2 fault code, i replaced the sensor, i havint had the limp home mod come back, yet. pcm plugs is the main plugs on the pcm. still sometimes the key will not rock back to off, so all i do is push in on the lil button and rock the key back at the same time.
Harley-Man
10-13-2016 10:42 AM
dagsler
08-10-2010 08:25 AM
96jimmy4x4in
10-07-2007 09:23 PM
