stupid codes
Old Jan 2, 2020 | 01:29 PM
loudnlow's Avatar
loudnlow is on a distinguished road
Default stupid codes
ok so first post in a while sorry, but been getting a p0452 code. recently replaced gas cap, fuel pressure sensor, and fuel pump seal. it didn't seem to fix the problem scanned and cleared the code and every time i turn off and restart the truck it comes back. I never get the whoosh when i take the gas cap off. not sure if its related to this or not but, i also suffer the 100 rpm jump at about 80km plus as soon as im steady with the gas any help would be appreciated
Old Jan 6, 2020 | 07:49 PM
Could there be a problem with the gas vapor recovery system?
Old Jan 7, 2020 | 05:51 AM
Just for the 100 rpm jump.
What is it doing exactly at that speed? In which gear?
Could simply be the TCC (torque converter clutch) engaging which it would do in the situation you describe. Should also be doing it in 3rd gear and 4th (OD). When it engages you will experience an rpm drop of around 100 - 200 rpm.
Old Jan 10, 2020 | 03:58 PM
loudnlow's Avatar
error_401
only at highway speeds 80km up to 110 don't drive much faster and its a 100 rpm jump repeated consistently like 30 seconds apart maybe
Old Jan 11, 2020 | 02:51 AM
Does it do this 100 rpm jump even with cruise control on a level highway?
Old Jan 11, 2020 | 09:53 AM
loudnlow's Avatar
yes cruise even tried it this morning its like every 3 seconds just jumps and jumps
Old Jan 11, 2020 | 11:35 AM
LesMyer's Avatar
Originally Posted by loudnlow
error_401
Mine did this only when 50mph+ (80 km), completely warmed up, and steady cruise in OD with TCC engaged. Not every 3 seconds, but maybe every 30 like you say. Bugged the heck out of me for several weeks. Even set a P0300 and turned on the SES light one time (but usually not). Then I drove 200 miles RT to Chicago and the transmission went out to the point that the vehicle wouldn't move unless you sat for several minutes to let all the clutch material fall off the fluid pickup filter. Otherwise it just sat there and howled because of no fluid to the pump. After trans repairs the problem went away. I think it may have been evidence of the pending trans failure, but I don't know that for fact. Please do follow up and let me know when you find out the source of the problem.
Old Jan 26, 2020 | 11:35 AM
loudnlow's Avatar
it does it continuous when im at highway speeds but seems to go away for a moment when i tap the breaks, it seems to gear down for a second then after a bit shifts and goes back. i find it more of an annoyance then anything and wondering if it have anything to do with my intake(have to do a lower intake gasket)
Old Jan 26, 2020 | 12:42 PM
GeorgeLG's Avatar
You might want to look at your TPS with live data, first at rest while smoothly moving and holding the accelerator through different positions to rule out a bod sensor. I agree with Les that this may be a transmission issue however.
George
Old Jan 27, 2020 | 05:42 PM
loudnlow's Avatar
it only happens in overdrive and sadly enough if a 6 month rebuild trans and still wondering if it could have any relevance to my toast lower intake gasket (being done tommorrow)
evo120
Sep 25, 2014 12:28 AM
moblakely
Jul 13, 2014 07:53 PM
Jakeduece
Jun 11, 2012 02:26 AM
THSteve
Apr 24, 2009 07:03 AM
cliro
Dec 11, 2007 02:05 PM
