Sudden No Crank condition - 99 ZR-2
Old Feb 23, 2016 | 01:56 AM
chevyragtopguy's Avatar
chevyragtopguy is on a distinguished road
Default Sudden No Crank condition - 99 ZR-2
Finish work at 2 AM, go to start truck nothing happens. Lights all work, horn works, battery is in good shape.
Crawl under, whack starter, nothing happens.
Also, lights do not even dim when the key is turned to crank it up.
Any help is appreciated.
Old Feb 23, 2016 | 05:18 PM
Check battery cable connections at both ends, positive and negative cables, (this will require taking them apart). They need to be shiny clean. If that doesn't fix it, you will need a voltmeter, and we can help you with diagnosis.
Old Feb 23, 2016 | 10:47 PM
Pretty sure it's the starter solenoid. Relay clicks, fuses are good. Battery terminals are nice a tight and clean.
I jumped it across the solenoid poles while in 'run' and it fired up and I got it home. Gonna go over it this weekend hopefully nice weather.
Old Feb 24, 2016 | 03:25 AM
LeWhite's Avatar
check starter relay: In the middle of the fuse box left side of engine. Just cause it clicks doesnt mean its good.
Also check ign switch.
Try to start in neutral not park.( checks grar selector sw.)
Old Feb 24, 2016 | 08:47 AM
With the ignition switch in the START position: Check for voltage on the solenoid stud that the purple wire attaches to, (not the wire, the stud). The purple wire comes from the starter relay and a poor connection there would give the symptoms you have.
Old Feb 28, 2016 | 10:28 PM
I found the wire to the solenoid was broken at the terminal. I cut it and crimped on another spade terminal and the Red Tonka is good to go!!! My kind of fix.....cheap and easy!!
Thanks everybody.
Buddykitchen
Dec 10, 2016 06:37 PM
g_mike
Aug 22, 2010 02:46 PM
hotrod28
Oct 14, 2007 09:37 PM
hogspeed
17
Aug 6, 2007 07:07 AM
HCCAFan
Feb 5, 2007 10:35 PM
