Surging - no rpm movement
RE: Surging - no rpm movement
Yes, the 4L60E does have TCC lockup in 3rd gear.
Does the surging go away when you lightly tap the brakes (holding steady on the gas pedal)? If so, this would lead me to believe that the TCC (torque converter clutch) is cycling for some reason instead of staying locked up. On the newer trucks, there are varying stages of lockup which can sometimes cause this condition...
ORIGINAL: swartlkk
I wonder why the issue only seems to be happening at higher speeds if it is the tc. I drive to work every day at 50 mph and I do not feel it then.
Probably just the power required to run at higher speeds making the clutch slip..?
ORIGINAL: Peru Motors
are you absolutely sure it's in the tranny? Wonder if you or someone you know has a scan tool that you can take out on a test drive, duplicate the issue and watch the 'misfire' screen and see if it is possibly a 'slight' miss. Had one once that I thought was tranny and my tranny guy drove it and said to do the cap and rotor(they weren't too old-1000 miles or less)and whola...that did it! Just my 2 cents and today it's on sale for free! Good luck-keep us updated! JP[X(]
It did not take the dealer long to find the solution. Opened the hood and sprayed some water on the lines and she was missing. Time for a tune up. Plugs, wires, cap, rotor, and I had the fuel injection flushed.
It will be much cheaper then I had planned. Thanks everyone for their input.
hmmmmm.....jp
814_fye
10-22-2009 01:10 PM
chevyman4life
06-09-2009 07:45 PM
