Surging - no rpm movement
Old Sep 25, 2008 | 07:29 AM
Default RE: Surging - no rpm movement
Yes, the 4L60E does have TCC lockup in 3rd gear.
Does the surging go away when you lightly tap the brakes (holding steady on the gas pedal)? If so, this would lead me to believe that the TCC (torque converter clutch) is cycling for some reason instead of staying locked up. On the newer trucks, there are varying stages of lockup which can sometimes cause this condition...
Old Sep 25, 2008 | 08:08 AM
mdkuni's Avatar
mdkuni is an unknown quantity at this point
ORIGINAL: swartlkk
I was wondering the same thing before you posted this. I will test that today and see what happens.
I wonder why the issue only seems to be happening at higher speeds if it is the tc. I drive to work every day at 50 mph and I do not feel it then.
Old Sep 25, 2008 | 08:11 AM
Probably just the power required to run at higher speeds making the clutch slip..?
Old Sep 29, 2008 | 06:47 PM
mdkuni's Avatar
ORIGINAL: Peru Motors
are you absolutely sure it's in the tranny? Wonder if you or someone you know has a scan tool that you can take out on a test drive, duplicate the issue and watch the 'misfire' screen and see if it is possibly a 'slight' miss. Had one once that I thought was tranny and my tranny guy drove it and said to do the cap and rotor(they weren't too old-1000 miles or less)and whola...that did it! Just my 2 cents and today it's on sale for free! Good luck-keep us updated! JP[X(]
It did not take the dealer long to find the solution. Opened the hood and sprayed some water on the lines and she was missing. Time for a tune up. Plugs, wires, cap, rotor, and I had the fuel injection flushed.
It will be much cheaper then I had planned. Thanks everyone for their input.
Old Sep 29, 2008 | 08:49 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
hmmmmm.....jp
Crawlblind
16
Feb 16, 2012 06:48 PM
vrryder
Nov 5, 2009 09:51 AM
814_fye
Oct 22, 2009 01:10 PM
chevyman4life
Jun 9, 2009 07:45 PM
mjd808
Mar 12, 2008 11:01 PM
