Swimming in Blazer!!
just wondering if anyone out there knew or has had this problem with their Blazer I've got a 1999 2 door Blazer 2 wheel drive 4.3 Vortec motor and I'm having an issue with the driver side floorboard is soaking wet. I mean I can smash my hand out on the carpet and it splashes it's so wet I know the heater core is on the other side and sometimes it leaks but why would I have water on the driver side floorboard drenched?
And one more question can I replace the compressor the AC compressor myself or do I have to have a special tool for the pressure lines my compressor is leaking freon so I guess I need to replace it any thoughts. And I'll let you know too that this Blazer set up for about 4 years and I got it running replaced a lot of stuff it's running good but I'm having a few minor problems any thoughts for Our advice would be much appreciated thank you guys and gals
This is my 99 2 dr blazer 148k 4.3 vortec
Two likely causes for your wet carpet are: leaking windshield or leaking drivers door seal due to damaged door hinge bushings and a sagging drivers door. Does the drivers door have to climb up the strike plate? Are the door hinge bushings crumbling?
Proper AC work requires:
Refrigerant recovery (not relevant if the system has completely leaked down)
Repair work
Pressure testing with nitrogen
Pulling a vacuum to remove all air and moisture from the system
Charging to an exact weight with a scale. using pure 134a with no oil or stop leak
Most people do not possess the proper equipment, even the minimum need for a vacuum pump.
George
Repair work
George
Wet carpet: get a hose and a friend. You inside, friend outside holding hose in a spot for 10-15 sec while you check for dripping. Just hose, no nozzle...gentle flow....do not want to fill-up the interior.
A/C: if all the Freon is gone, then yes you can unbolt the compressor and replace it. Also replace the accumulator and orifice tube, and any O-rings on the lines that you separate. Then take to an AC shop for rest of the job. The shop can pull the system down for a couple of hours, check for leaks, add the right amount of oil and R-134a...get you cooling down.
Swimming....
Thanks for your responses guys.. as far as the driver door sagging or worn out bushings, I dont think I'm having a problem there. I do know that my blazer sustained an injury on front left side qtr. panel before I bought it. So some things still are not aligned well etc.etc. I will get with a buddy and try to find my leak. Geez. that was a no brainer... but yet I didn't know of it ha!
a/c work will commence soon. Thanks for the info..
I absolutely enjoy being a member here....
Does it have a sunroof? I've seen several posts in the past of the sunroof drain tubes getting clogged and causing water to pool on the floor boards I even had it happen in my jetta when I first got it before I cleaned out the tube. Just another thought...
Also check below the carpet. It's a bit of work. You need to remove the A-pillar covers and the door sill covers, then you can fold the carpet back.
I've had my other Blazer leak because of a rusted joint between the firewall and the floor pan. This seam runs across the truck about 5" above the floor pan. That's slightly higher then the bend in the floor pan. You can see that through the wheel well. Sometimes the location of the seam is visible through the sprayed-on underbody protection.
Another place where it can rust through is around the cab support in that corner. That is slightly aft of the A-pillar but on the floor.
If checking with LannyL81's method which is a very good starting point, also do the grille in front of the windshield and the corner of the hood. While doing this also look under the dash.
Another source for water to come in the passenger side footwell area is the antenna wire. It passes through a grommet, but if there's been any fiddling around under the dash or in the engine bay around where the wire passes though, that grommet can become dislodged. The water then runs right down the antenna wire and into the cab, where it drips on the floor.
Dealt with it myself on my 2004 a couple years back... My solution was to push the grommet back in and slather it in clear silicone. Haven't had a problem with it since.
swimm
Thanks for all the help guys...
CraigSnedeker
07-19-2018 07:53 PM
