Swooshing (Nike) sound when turning.
Old Jun 12, 2011 | 08:26 PM
oldmike's Avatar
oldmike is on a distinguished road
Default Swooshing (Nike) sound when turning.
Hi Blazerites,
New to the forum, hope u can help.
I have a '96 S10 2 dr , auto tran Blazer with 78,000 miles on it.
I've owned it since 1996 (second owner).
The problem:
When turning, there is a distinct swoosh-swoosh-swooshing sound. It seems to be louder when turning right. I've checked the power steering fluid level and it's OK. At first I thought it was brakes, so I replaced all the rear brake's hardware and shoes. I replaced the front pads also.
Someone suggested it was the torsion bars that run along side the frame.
The sound is soft, not metalic and doesn't increase in speed when I speed up or slow down.
I do as much of the work as I can, but this one has me stumped.
Thanks for ur input.
Mike
Old Jun 13, 2011 | 07:48 AM
Sounds like a failing left front wheel bearing. I know you said it doesn't change with speed, but does the frequency of the sound change with speed?
Old Jun 13, 2011 | 10:03 PM
oldmike's Avatar
Thanks for ur inut smartlkk, I'll pull the front wheel bearings and see how loose they are.
Old Jun 13, 2011 | 10:36 PM
Rottidog's Avatar
"smartlkk"? yes he is! New name for Kyle lol
Old Jun 14, 2011 | 07:43 PM
oldmike's Avatar
smartlkk, I have a 4 whl dr, would the bearing ur referring to be in the hub and bearing assembly? Looking at my repair manual, it says that the assembly is sealed and isn't servicable ie. buy a new one.
Mike
Old Jun 14, 2011 | 07:46 PM
Rottidog's Avatar
Yup that's it! Buy as best as you can afford & make sure you torque it to specs & the directions. There's a link in forum about replacing a hub assembly, just do a search for Hub Assembly in DIY I believe. If you don't have the socket &/or torque wrench you can probably borrow (with a deposit) or rent 1 for a day at a lot of parts places.
Old Jun 14, 2011 | 07:58 PM
oldmike's Avatar
Thanks ROTTIDOG, I guess its off to NAPA.
That skull in ur grill emblem looks like my driver's license picture!!
Old Jun 14, 2011 | 09:22 PM
Rottidog's Avatar
Wow oldmike IS old if you look like that emblem lol.
https://blazerforum.com/forum/articl...-thread-43645/ here's the link to the Tech Articles (DIY) > Article Submissions/Discussions HOW-TO: 4WD Front Hub Replacement - DISCUSSION THREAD
... and my pleasure.
ibsam2005
Mar 2, 2012 05:04 PM
BlaZeR FXB1581
Jul 2, 2007 07:51 AM
vdog
Jan 10, 2007 04:46 PM
Gunner Woody
Feb 15, 2006 05:14 AM
BlaZinNaTe
Suspension Tech
Dec 30, 2005 12:41 PM
