"System Too Rich Condition", leaking coolant from the lower intake manifold?
#21
I was checking the o2 sensors and while checking the ground wires with my multimeter, I got three dings when checking the female end connector for the passenger side o2 sensor. Now shouldnt there only be two ground wires for both the sensors? I only get two dings when checking the driver side o2 connector. And if I'm getting a bad ground wire on the passenger side connector would that be causing the rich condition?
#22
LTFT indicates it's running rich, and the O2 sensor readings confirm it. O2 sensor voltage is supposed to cycle up and down between 0 and .9VDC, perfectly normal. In post #2 I asked about fuel pressure and leakdown, your response was, "The fuel pressure is also fine, checked that when checking the lines for clogs." What are the readings using this procedure:
1) Key ON, engine OFF, fuel pump running?
2) What is the pressure 10 minutes after the pump shuts off?
737mechanic
02-07-2015 05:21 PM
Melrock83
07-03-2012 06:51 AM
ded2klf
11-29-2010 10:15 PM
vagnozzi
09-14-2007 08:40 AM
