T-case problems
T-case problems
I have a 99 Blazer with the T-case 4x4 Auto option (4 button). When I put it in 4x4 auto the service 4x4 light comes on and I get a C0374 code and when I put it into 4x4 hight I get a C0305 code. I have checked all the plugs on the t-case and all look clean and OK. Where is the front propshaft speed sensor located so I can test it? I am thinking the C0305 code is the C0374 code problem.
Also if I find that it's bad, anyone have a part # so I can order online.
C0305 - Front Propshaft Speed Sensor System Malfunction
C0374 - General System Malfunction
The C0305 code can definitely cause the C0374 code so start there. Inspect the wiring harness to the front speed sensor for damage as this can cause a C0305 code to set. The front prop speed sensor is located near the front output shaft on the top of the transfer case.
Flyfishen
06-18-2019 11:22 AM
bensaintonge
12-03-2013 08:14 AM
upblazer95
04-04-2009 08:27 PM
mlprus
02-14-2009 07:02 PM
loscochinos520
05-28-2005 11:32 PM
