Tach cuts out and engine stalls
Old Aug 21, 2012 | 09:22 AM
burned's Avatar
burned is on a distinguished road
Default Tach cuts out and engine stalls
97 S10 4.3L. On the way to work this morning the tachometer cut out and the engine died for a brief second, then came back. When I got to work the engine died completely, same scenario (Tach goes to zero, engine dies). The headlights and stereo were still on. It started back up after a few tries.
I hope its the ignition control module, I have a spare under my seat.
Old Aug 21, 2012 | 09:50 AM
Rottidog's Avatar
I had something similiar happen. It would just stop. The tach stopping is because the engine has stopped. Turned out to be a wire in the large wiring harness/loom coming from the fuse box under the hood. I got lucky in finding it by wiggling wires till the fuse popped again. Then narrowed it down & found the wire broken inside the insulation.
Old Aug 21, 2012 | 10:19 AM
spittybays
Guest
Posts: n/a
+1 pull and wiggle. Did you ever have the ignition switch changed. 97 could about it's life span.
Old Aug 21, 2012 | 09:22 PM
+1 on the ignition switch, very common on 1997.
Old Aug 27, 2012 | 09:11 AM
burned's Avatar
Replaced the ignition switch and no more problems.
Thank you.
The contacts on the original one:
Old Apr 25, 2013 | 03:55 PM
S.Hafsmo's Avatar
S.Hafsmo is on a distinguished road
I just had a similar stall on my 98 (gauges jumping, lights flashing etc.), is the 98 prone to this ignition switch problem?
Old Apr 25, 2013 | 07:48 PM
1997 ignition switch was unique to that year, and it was common for them to act up. It can happen on any year though.
Old Apr 26, 2013 | 04:14 AM
S.Hafsmo's Avatar
Thanks. I should probably start a new thread on the subject, but are there any other issues that could cause something that would appear as shutting the ignition off/on while driving?
To me it sounds like improper grounding/battery connection, or a broken wire to an ignition module or similar. Anyone got any experiences like that?
The engine just cut while driving, and the gauges/lights in the dash flashed like they do when you turn the ignition on in the morning. First time this happened was after hitting a bump in the road. Engine starts right up afterwords.
dieseltwitch
Oct 13, 2010 11:10 PM
ctberry78
Mar 24, 2009 08:33 AM
KIllarb634
Dec 2, 2007 03:08 AM
Roma
Jun 18, 2007 03:04 AM
budiblazer
Jun 21, 2006 10:01 PM
