General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Engine cuts out at 3000 rpm on 95 Blazer
Old Mar 19, 2006 | 10:38 PM
budiblazer's Avatar
budiblazer is an unknown quantity at this point
Default Engine cuts out at 3000 rpm on 95 Blazer
When accelerating over 3000 rpm, the engine sputters and looses power. I then need to take my foot off the gas pedal until it regains power. I had a new fuel pump put on and replaced the fuel filter. I have no service codes showing. Was wondering if it could be a sensor.
Old Mar 20, 2006 | 01:16 PM
Hanr3's Avatar
Default RE: Engine cuts out at 3000 rpm on 95 Blazer
When is the last time you had a tune up?
Old Mar 21, 2006 | 12:03 AM
budiblazer's Avatar
It has new plugs and wires. It sputters when going over 3000rpm, when you 1st start the vehicle you can run it over 4000 rpm in drive but soon their after it starts to sputter. Thought maybe a map sensor or ignition module.
Old Mar 21, 2006 | 03:30 PM
Hanr3's Avatar
until it warms up the IAC controls things. Surprised your not getting any codes. It should trip something, unless its fuel related. Like a paritally plugged fuel filter, or fuel pump not pushing enough fuel. Could be a MAP sensor as well, or a vacuum leak screwing up the MAP sensor.
Old Jun 21, 2006 | 10:01 PM
budiblazer's Avatar
I'm wondering if it's the manifold tuning valve. Would that cause my transmission to shift longer in each gear?
fbaker25
Nov 15, 2019 03:41 PM
fbaker25
Oct 14, 2012 11:49 AM
Aanenson
Feb 1, 2012 11:00 AM
TheMoneyPit
Feb 18, 2011 08:31 AM
ctberry78
Mar 24, 2009 08:33 AM
