tach reads slow
Old Sep 23, 2013 | 08:15 PM
dpmeeks's Avatar
dpmeeks is on a distinguished road
Default tach reads slow
I just got me a 98 Blazer 4x4 4.3 engine. It has about 189k on it. The tach doesn't seem to be accurate with the revs of the engine. Is there a known issue with this ?
Old Sep 23, 2013 | 08:24 PM
rriddle3's Avatar
No, it is not a known issue. How exactly is it not being accurate?
Old Sep 23, 2013 | 08:30 PM
dpmeeks's Avatar
it just seems kinda lazy when revving the engine, kinda hard to explain, it almost bounces around..
Old Sep 23, 2013 | 08:32 PM
rriddle3's Avatar
Perhaps the distributor gear is worn.
Old Sep 23, 2013 | 09:23 PM
Possibly the stepper motor that operates the tach needle is binding, or has a poor connection somewhere. The signal originates at the CPS, (Crankshaft Position Sensor) and is sent directly to the PCM. Serial data is sent to the BCM, and the BCM sends the data to the logic module in the instrument cluster. A bi-directional scan tool capable of accessing the BCM can force a needle sweep to see if the BCM can command the tach, and see if it responds correctly. Without the scan tool, diagnosis is difficult.
EDIT: correction
Old Sep 24, 2013 | 06:32 AM
dpmeeks's Avatar
thanks for the info captain hook !
BusaJoe
Oct 21, 2009 09:41 AM
smoothedoggie
Feb 14, 2009 04:38 PM
blazerguy22
Dec 12, 2008 07:59 PM
diggler149
Mar 30, 2007 09:05 PM
Jimmysls98
Feb 28, 2007 10:40 PM
