Hesitation/sputter when flooring the blazer
Old Jun 5, 2013 | 05:20 PM
thibault116's Avatar
thibault116 is on a distinguished road
Question Hesitation/sputter when flooring the blazer
hey i have a 01 Chevy blazer iv done intake gasket,egr tube ,plugs, distributer cap and router, fuel filter,plugs cleaned throttle body and maf then i had po155 code so i did a o2 sensor bank 2 sensor 1 i think that's what po155 code is. hoping it would fix it. the fuel filter stoped it from sputtering and hesitating until i filled the tank again i thought it was bad gas. the blazer still hesitates and sputters at wot or under a load. idles fine runs good starts right up last time i checked the fuel pressure it was fine (2 months ago) i dont know what else to do its driving me nuts. if someone could help me out it would be greatly appreciated thanks for your time.
Old Sep 22, 2013 | 01:36 AM
Wild_Thing XI's Avatar
Wild_Thing XI is on a distinguished road
I have a similar problem with my 99. My friend hooked his diagnostic computer to it and it showed that the Fuel Tank Pressure Sensor was showing a code. Im trying to find anyone else that has dealt with this as well so I know how much it costs and where it is. I hope this kind of helps,lol.
Old Sep 22, 2013 | 03:35 AM
HcHawks09's Avatar
Sounds like Throttle Position Sensor (TPS)
When you press the gas pedal the needle in the TPS moves, sending a signal to the computer to send more fuel to the engine. If the TPS goes bad there will be a dead spot(s) and when the needle hits that dead spot the computer will starve your engine of fuel causing the sputter/bog.
Old Sep 23, 2013 | 04:18 AM
Wouldn't that show up on the computer? I am not doubting you, just saying if it were the problem I think it would show up on the diagnostic. I can live with it for the time being but it is something I will surely fix in the coming months.
Old Sep 24, 2013 | 06:58 AM
xillzxnickx's Avatar
xillzxnickx is an unknown quantity at this point
Spider injectors might be going bad
If you know how to do a injector balance test
Old Sep 24, 2013 | 11:38 AM
burned's Avatar
burned is on a distinguished road
Any codes? Does the CEL flash when under load or WOT?
lilwhite219
Apr 28, 2013 09:53 PM
foreveryoung
Jun 28, 2011 11:13 PM
lush1_79
Apr 20, 2011 09:05 PM
blazeric
23
Apr 13, 2009 08:01 AM
XBlazer01
Aug 17, 2006 11:42 AM
