Taking of the dashboard - how to do that
Old Sep 17, 2010 | 08:54 AM
miffalek's Avatar
miffalek is on a distinguished road
Default Taking of the dashboard - how to do that
Hi
The switch that turns on the lights doesn't work, the transmitter behind the dashboard burnd down. My question is how to tak down the dashboard? Perhaps you've got some manual or fotos for this
I've got a 1995 Blazer 4,3L atomatic 4WD.
THX
Old Sep 17, 2010 | 10:24 AM
hemivette's Avatar
hemivette is on a distinguished road
There are two screws above your gauges that holds the trim peice that goes around your instrument cluster and stereo and heating controls......After you remove the screws, you just grab that peice and gently pull it towards you, working your way around until its all loose. Then if I remember right, you disconnect the wires going to your 4X4 switch, lower the tilt on your steering wheel and pull the trim peice allthe way out. After that the switch is right there, just swap it out.
Brooklin67s
Feb 2, 2007 09:24 PM
railfire96
Feb 1, 2007 10:53 AM
DCFluX
Oct 5, 2006 04:23 PM
sktdarkstar8
Sep 18, 2006 10:45 PM
JasonG
Dec 12, 2005 02:19 PM
