tbi question?
Old Nov 20, 2008 | 04:59 PM
salvy's Avatar
salvy is an unknown quantity at this point
Default tbi question?
What's involved in removing the throttle body on a 4.3 ? Today I sprayed some TBI cleaner in it as directed and wiped out the base of the body and the carbon was loaded in there, I mean loaded, so I was thinking to remove the whole unit and clean it thoroughly. The truck runs new, but, I want to get this crap out and maybe it will run even better, with a 100k on the clock, any suggestions?
Old Nov 20, 2008 | 09:08 PM
cr8390's Avatar
cr8390 is an unknown quantity at this point
Default RE: tbi question?
[ol]1. Disconnect the negative battery cable.
2. Disconnect the IAT sensor harness connector.
3. Disconnect the breather tube from the air cleaner outlet duct.
4. Remove the air cleaner outlet duct retaining wing nut.
5. Loosen the clamp on the outlet of the MAF sensor.
6. Lift the air cleaner outlet duct from the throttle body and remove the assembly from the MAF sensor.
7. Remove the air cleaner adapter stud.
8. Disconnect the cruise control cable from the throttle body.
9. Disconnect the accelerator cable from the throttle body. [/ol]
[ol]10. Remove the nuts retaining the accelerator cable routing bracket and position bracket aside.
11. Remove the stud and nuts retaining the accelerator control cable bracket and position bracket aside.
12. Disconnect the IAC valve harness connector.
13. Disconnect the TP sensor harness connector.
14. Remove the throttle body retaining studs.
15. Remove the throttle body assembly.
16. Discard the throttle body seal. [/ol]
[ol]Pics are uploaded steps 1,2,3,4 (5 no pic),6[/ol]
[IMG]local://upfiles/10186/36AFB30304344D2BBADB1C8C260DD2BA.gif[/IMG]
[IMG]local://upfiles/10186/875D2CF681AD4DF390C96C9DA59D5763.gif[/IMG]
[IMG]local://upfiles/10186/E8223CD8A869495D8ACAB522DECE8E92.gif[/IMG]
[IMG]local://upfiles/10186/80164A1F62234339AF965E4BF468DADB.gif[/IMG]
[IMG]local://upfiles/10186/5BAB5BD209574F9EB7F0EA7D861F172F.gif[/IMG]
Old Nov 20, 2008 | 09:21 PM
cr8390's Avatar
Steps 7,8,9,10,11
[IMG]local://upfiles/10186/0D8106EEC89B4325977382C350945EA4.gif[/IMG]
[IMG]local://upfiles/10186/18A9FA584B1C4C60A3A682653254B59F.gif[/IMG]
[IMG]local://upfiles/10186/B93B3ECAA5C14C1CA924F9442794967F.gif[/IMG]
[IMG]local://upfiles/10186/7CFA1DF62AE04B8AA887111C63BCFEC9.gif[/IMG]
[IMG]local://upfiles/10186/31F5985979CE48B0BF9F661E12A9E541.gif[/IMG]
Old Nov 21, 2008 | 04:47 AM
salvy's Avatar
nice pic's - thanks
Old Nov 21, 2008 | 11:24 AM
cr8390's Avatar
made a DIY here: https://blazerforum.com/m_185850/mpa.../tm.htm#185850
dragnblazer
Jan 12, 2012 10:13 PM
deathman
Aug 14, 2011 11:25 PM
maverik78
Performance & Brainstorming
Apr 11, 2010 10:05 PM
RnB1987
Engine & Internal
Jan 27, 2010 08:49 AM
deanosride
May 18, 2009 12:13 PM
