Temp sending unit question
Old Jan 24, 2018 | 04:41 PM
GreenBlazer2002's Avatar
Default Temp sending unit question
Other than an inaccurate gauge reading, would a failing temperature sending unit exhibit any other symptom? Would it cause engine performance issues such as stalling or hesitation? I'm having multiple performance problems and trying to avoid throwing unnecessary parts at it. I've spent a ton of time and money on this thing already and I'm just about to give up on it. Thanks for your responses.
Old Jan 24, 2018 | 08:50 PM
oldeerslayer's Avatar
oldeerslayer is an unknown quantity at this point
Yes a faulty ECT sensor will make the truck think it is -40° outside and add way too much fuel resulting in crappy running. You gauge gets the reading from the PCM if your Blazer is an 02. Corrosion on the connector will also cause the same issues. I'm talking about the one on the front of the engine. (only one on an 02).
Old Jan 24, 2018 | 09:10 PM
Excellent. This forum is the only reason I can't quit this Blazer.
Y'all rule!
Old Jan 24, 2018 | 09:15 PM
Among those seen above, which would the members of this forum recommend?
Old Jan 24, 2018 | 10:12 PM
I'd go with the first one.
Old Jan 24, 2018 | 10:34 PM
Old Jan 25, 2018 | 06:32 PM
I have ordered the AC Delco OEM replacement unit, as well as a new thermostat and radiator cap. Should arrive tomorrow.
Will install Saturday.
Will post results.
If memory serves, the unit is located on the intake manifold near the thermostat housing, as the diagram indicates. Correct?
Old Jan 26, 2018 | 04:32 AM
Will post results.
Nevermind. Found it.
Old Jan 26, 2018 | 09:06 AM
LesMyer's Avatar
I thought it was in the driver's side head on my 2001 IIRC.
Old Jan 26, 2018 | 06:33 PM
correct.
