Temperature not reading, heat not very hot
Old Nov 18, 2009 | 06:17 PM
JSBlenz9498's Avatar
JSBlenz9498 is on a distinguished road
Default Temperature not reading, heat not very hot
As the title says, my temp guage isnt reading at all and my heat isnt very hot. Anyone had this problem? Would it be worth throwing a new thermostat in?
Old Nov 18, 2009 | 06:32 PM
terry s's Avatar
terry s is on a distinguished road
The 2 most likely causes are thermostat or temp. sending unit. The thermostat is the most likely cause. You can take it out and check it with a thermometer and a pan of water on the stove but if you take it out you might as well replace it. Not a bad idea to check the new one against the old one with the thermometer. New ones can be bad sometimes.
Old Nov 18, 2009 | 07:41 PM
jackdaroofer's Avatar
jackdaroofer is on a distinguished road
There could be another cause...you may be very low on coolant
Hope I am dead wrong
Old Nov 18, 2009 | 08:36 PM
ya thats what i figured. Im just going to put a new thermostat in it. Not like i'll hurt anything
Old Nov 18, 2009 | 10:05 PM
terry s's Avatar
If the temp reading were normal with low heat output I would have suspected low coolant level. But unless he has 2 problems at once it is likely the thermostat.
Carl@gmail
Feb 1, 2015 03:20 PM
Benzarch
Jan 24, 2014 07:27 PM
blazerxtreem
Jul 12, 2013 08:06 PM
Mandrwj
Apr 10, 2011 07:32 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
