Is There a Ventalation Motor in the Door?
Old Nov 23, 2008 | 08:33 AM
wienerdog's Avatar
wienerdog is an unknown quantity at this point
Default Is There a Ventalation Motor in the Door?
My 2nd Gen Jimmy...for the first 10 mins or so after turning the ignition on or starting my Jimmy I can hear what sounds like an electric motor running. Sounds like its coming from inside the left body panels maybefrom a door. Its not the fuel pump because I can hear the FP charge and stop. This noise doesn't stop. Sounds like its somekinda ventalation fan motor.
Any ideas?
Old Nov 23, 2008 | 02:19 PM
Default RE: Is There a Ventalation Motor in the Door?
Please include your vehicle information in your signature (year, drivetrain, etc).
Do you have auto-climate control? If so, the interior temperature sensor is located directly above the driver door. On the outside it is a small plastic grill. Inside is a temperature sensor and a fan that pulls air from inside the cabin over the sensor.
This thread should explain things quite well:
Weird sound, weird speaker-like device on driver's side
If it is making noise, then it is very likely that it is quite dirty. You can try cleaning it and seeing how it sounds then. If it is still making noise, then you could live with it, or replace it.
Old Nov 23, 2008 | 05:29 PM
Mammys Car's Avatar
Mammys Car is an unknown quantity at this point
It's perhaps the canister purge pump (clears the charcoal canister of trapped fumes from the gas tank).
Old Nov 23, 2008 | 06:09 PM
The canister purge pump is also known as the engine itself...
Old Nov 24, 2008 | 10:05 AM
blazin8556's Avatar
blazin8556 is an unknown quantity at this point
i have heard older suburbans make a ticking sound from the middle of the dash.i know this has nothing to do with the above, just thought i would make a comment
Old Dec 1, 2008 | 09:46 PM
wienerdog's Avatar
Yeah, auto climate control. I never noticed that grill above my head. Thanks.
Sig is changed.....
Helter80
Dec 23, 2024 10:04 AM
shotnva777
Sep 10, 2011 01:14 AM
fast eddy
Performance & Brainstorming
Aug 1, 2010 09:45 AM
mcaanda
May 23, 2009 04:04 PM
