Throttle Blade Sticking
Old Dec 16, 2011 | 06:32 PM
bigkeith11's Avatar
bigkeith11 is on a distinguished road
Default Throttle Blade Sticking
So I cleaned my throttle body; took the IAC out and cleaned that, took the blade out and cleaned it with degreaser and steel wool. Now the blade will stick open and I have a P0507. My rpms in neutral are about 1500! And driving it will stay around 1500 also. If I pop the hood I can close it all the way and it sits at normal idle.
Old Dec 16, 2011 | 06:34 PM
Sounds like you didn't get the blade put back on perfectly centered on the throttle shaft. Try loosening the screws and allowing the throttle do close all the way, then tighten the screws back into place. Also, you should use red loctite on the throttle blade screws to keep them from backing out.
Old Dec 17, 2011 | 06:28 PM
bigkeith11's Avatar
I had a spare throttle body in my garage. Cleaned it up with some super clean and reinstalled it. Runs perfect!!!! But now I have a new code, P0140. My dad had the truck before me and replace all the sensors except the one after the cat.
ComputerNerdBD
Oct 3, 2022 01:34 AM
slcblazer
Headers, Intake, & Exhaust
54
Feb 28, 2017 06:58 PM
FOGEL
Feb 22, 2013 10:36 AM
96chevblazer
Performance & Brainstorming
15
Oct 7, 2009 09:01 AM
azembdriver
Jul 19, 2009 03:12 PM
