Throttling Problems
Old Aug 23, 2023 | 12:46 AM
PScholl68's Avatar
PScholl68 is on a distinguished road
Default Throttling Problems
Yes having serious acceleration problem my Blazer once it is started it excellerates the RPMs off the charts, you don't even have to touch the gas peddle. I drove to town and back and the throttle never dropped below 1500 rpms. The only reason I drove it like that was to get my wife to her Dr.'s app, I changed the tps , Mas, air, all vacume hoses tap, I'm wondering what it can be. It's really dangerous to drive it it almost ses like the cruise control is driving it all the time.but it dosent work.Can someone give me some advise,please
Old Aug 23, 2023 | 07:41 PM
GeorgeLG's Avatar
  1. Do you have a scanner that can read live data?
  2. Do you have any codes?
  3. Did any work or changes precede this issue?
  4. Have you looked at the IAC valve yet?
  5. Have you cleaned the throttle body?
  6. Does this still happen if you disconnect the throttle cable at the throttle body
George
Old Aug 23, 2023 | 09:21 PM
PScholl68's Avatar
George
well I can't get any codes because my data link isn't responding I've cleaned the throttle body and a new iac valve.I haven't tried to disconnect the throttle cable yet, it has done this sporadically over the last few months but it's got bad after I've been having problems with my 4wd engaging and disengaging.just acouple of days ago replaced 4wd actuator cable.
Old Aug 23, 2023 | 09:25 PM
GeorgeLG's Avatar
What year and engine?
George
Old Aug 24, 2023 | 11:44 AM
Hess13x's Avatar
Check the throttle cable. Had the wife's 97 start idling high an throttle cable was sticking. Lubed it up and all is good. I did order a new one though
Old Aug 24, 2023 | 01:40 PM
In the very short term, see if you can pull up the accelerator pedal with the toe of your shoe while sitting in park.
Old Aug 24, 2023 | 02:20 PM
PScholl68's Avatar
George
it's 2000 LT 4.3 4wd 4 button automatic 4wd/Allwd
Old Aug 27, 2023 | 10:15 PM
PScholl68's Avatar
Yes wondering if anyone has the diagram of throttle cable adjusting diagram or schematic. Also how to adjust the throttle body butterfly valve
scubacamper
Sep 10, 2013 12:16 PM
potsy78
May 19, 2013 07:44 PM
knightstar
Jul 2, 2012 09:57 AM
Crawlblind
16
Feb 16, 2012 06:48 PM
porkfriedrice
16
Sep 9, 2010 10:55 PM
