Torsion bar rear end (mounts,links)
Old Oct 18, 2007 | 07:13 PM
fernandoh's Avatar
fernandoh is an unknown quantity at this point
Default Torsion bar rear end (mounts,links)
Any of you have a diagram or similar info about the parts that are located in the rear extreme (rear end) of the torsion bars of a 2000 4wd ?. I will appreciate any comments because I'm trying to kill the clickings I've centered in the area.
Old Oct 18, 2007 | 09:31 PM
mdehoogh's Avatar
Default RE: Torsion bar rear end (mounts,links)
this was the only diagram i could find. it says its for 83-94 trucks but the torsion bar setup should be very similar, if not the same, for your truck... CLICK
Old Oct 19, 2007 | 02:26 AM
fernandoh's Avatar
Thanks. I have the idea that in 1999 the hardware for the rear link of the torsion bars changed. As an example comparing your diagram with my truck, the "cross member" is held in place using some 20 cm long bolts or links, isolated with donut rubbers, very similar to that in shocks.
98BlazerLT4x4
Oct 28, 2008 08:18 AM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
S10Blazer
Dec 23, 2007 10:47 AM
samurai_24
Sep 26, 2007 09:22 AM
