Sway Bar End Links
Old Sep 25, 2007 | 04:15 PM
samurai_24's Avatar
samurai_24 is an unknown quantity at this point
Default Sway Bar End Links
2000 Blazer 4x4 LT 4.3
New to front end and suspension work. How exactly do I check and replace end links for the front sway/stabilizer bar? Thank you. This site is such a great resource. My blazer has swayed as long as I can remember. The ride is still "bouncy" and the vehicle rocks and sways when I hit dips on the freeway or go over big bumps. I replaced all 4 shocks last year, which helped a bunch, but it still is quite noticeable. The wife doesn't like to drive it because it doesn't "feel safe" going down the highway.
Old Sep 25, 2007 | 04:37 PM
Default RE: Sway Bar End Links
Basically take a look at them... The sway bar end links are not much more than a bolt, spacer, some washers and the bushings themselves. Typically, the bolt will break before the bushings wear out. It is fairly cheap to replace these with polyurethane bushings for improved response, but it won't be dramatic unless you have a broken end link.
Old Sep 26, 2007 | 09:16 AM
samurai_24's Avatar
Does the bolt need to be a certain torque?
Old Sep 26, 2007 | 09:22 AM
11ftlbs
blazerJim1701
Oct 21, 2010 05:30 AM
blzrls
Apr 7, 2009 04:13 AM
MeidleinA
Apr 15, 2008 11:06 PM
95BlazerLt4wd
Lifting Tech
Mar 4, 2008 08:58 PM
phins54
Lowering Tech
Nov 26, 2007 05:48 AM
