Total coolant capacity include expansion tank?
Old Sep 29, 2018 | 05:49 PM
Default Total coolant capacity include expansion tank?
Hi all,
Quick question: Does the total coolant capacity listed for my 1999 Blazer of 11.7 quarts include the volume of the expansion tank? If yes, to what mark on the expansion tank; the "full" mark when the engine is hot?
Thanks
Old Sep 29, 2018 | 09:15 PM
G0LFADD1CT's Avatar
G0LFADD1CT is an unknown quantity at this point
I believe that the manual lists the total quantity if the engine and heater core are completely dry...ie: new.
Old Sep 29, 2018 | 09:26 PM
Yeah but does it also include the overflow/expansion tank? I would think it does but I have never seen it documented as such.
Old Sep 29, 2018 | 10:31 PM
G0LFADD1CT's Avatar
I can't recall seeing it either. Sorry, I'm not much help.
Old Sep 30, 2018 | 05:05 PM
I just now measured the volume of the overflow (expansion) tank for my cooling system. The volume to the Add mark is 2 cups (1/2 qt) and the volume to the Full mark is 6 cups (1.5 qts).
That would leave 11.7 - 1.5 = 10.2 quarts in the rest of the system.
Old Sep 30, 2018 | 09:57 PM
Last update: I drained and refilled with distilled water 5 times. I know, I know, that might be excessive but I had already purchased that water. On average, I could get about 1.25 gallons out by draining just at the radiator drain. That 1.25 is almost exactly 1/2 of the 2.55 gallons I calculated of the cooling system not including the overflow container.
By jacking up the right front corner and removing the right side hose to the heater core, I could fill in as much antifreeze as I wanted and could see it displacing water that would come out of the heater core. When I had put in about 1.25 gallons of antifreeze into the radiator I reattached the heater core hose. When reattaching the hose I could see there was water at the heater core and in the hose as I attached it so no bubbles.
I used the remaining ~0.25 gallons of antifreeze mixed with about the same amount of distilled water to fill the expansion tank to about the Add mark. After I drive it next and it gets hot, I'll top off the expansion tank with a bit more distilled water if necessary.
MEGearHd
Apr 6, 2019 09:06 PM
nbguide
Feb 4, 2014 07:46 PM
ComputerNerdBD
14
Mar 23, 2010 05:28 PM
cnmcconnell
May 17, 2009 05:14 PM
lennyblazer
Jun 19, 2007 06:03 AM
