tps?
Old Sep 23, 2011 | 05:55 PM
randyw's Avatar
randyw is on a distinguished road
Default tps?
Hey guys new here. Hope this hasn't been covered and i was searching for the wrong thing, but i was woundering if the issues i'm having is caused by the tps? I have no way of testing it the way all my searching has instructed. So i will give the run down on what's going on and see what you guys think.
About a wk or so ago my 95 started taking longer to start up, meaning it took several more cranks then normal. Then it has progrest to very rough idle while stopped and i mean rough( teeth chattering), and as pulling out it hesitates up till it shifts then it will slowly clear up. I changed the iac for giggles since i had one laying around. Still same thing. Well just now as i was tinckering with it i took out the screws to the tps and started it up and slowly moved the tps foward and backwards. Anywhere but where the tps is supposed to be it idels perfect. I don't know if that's a way of determing it is the tps or not so i turn to u guys before i start dumpin money i don't have into this thing.
Thanks in advance.
Old Sep 23, 2011 | 05:59 PM
tibby's Avatar
Default .
Thanks in advance.
I would try cleaning the throttle body and the tps. The rule of thumb for me is try cleaning something (like the egr valve or tps) before replacing it. Cleaning is free, so that would be my first option.
Old Sep 23, 2011 | 06:03 PM
TEST TEST TEST! If you don't own a multimeter, go pick one up. A few paper clips straightened out and ends smoothed make cheap back-probe tools.
Old Sep 30, 2011 | 05:45 PM
kristoph30's Avatar
kristoph30 is on a distinguished road
Multimeters are cheap now days. I have a really good one I under the hood, Cost me a whole ten bucks at walmart. I also bought a $4 meter at harbor freight i lend out. that way if it doesnt come back i dont cry about it.
Old Oct 3, 2011 | 06:45 AM
randyw's Avatar
Ok desperate now. Went to advance auto and had my codes pulled. Got iat high circuit, tps low circuit and oxygen reading rich. So replaced tps and iat and nothing, actualy worse now. Checked egr it's been replaced before i got the blazer and they also used the gasket with the screen on it. I'm at a loss and can't afford it anymore it's running so bad now that at a stop u have to hold the gas at 1500 rpm to keep it running while other foots on brake. Costing me 30 bucks a day to drive to work and back home only. I read somewhere that the iac will also cause the problems i'm having and wont always throw a code, true? Oh and chgd the plugs too they was blacker than black it's self which i expected seeing how it's running so rich. Any thoughts? Need fixed asap only vehicle at this time and i'm becoming unable to afford to drive it.
Old Oct 3, 2011 | 08:45 AM
bromanjr's Avatar
bromanjr is on a distinguished road
If its costing you more in fuel ($30 a day compared to what?) and the plugs were black, you probably have a leaky Fuel Pressure Regulator or something else dumping fuel inside the intake plenum. Clogged CAT is happening and you will have no power soon.
You need to check fuel pressure and leakdown.
Old Oct 3, 2011 | 09:33 AM
pettyfog's Avatar
Sidebar:
{Added: brain fart here.. some reason I mixed up the OP and a responder.. D'oh!}
broman.. you really arent helping much.
It's natural that folks look at advice in different ways... but here we have a guy who has problems related to sensor voltages and ignores advice to read them. Goes to autozone and doesnt bring back specific codes, only the clerk's interpretation of those codes.
- throwing parts at a problem doesnt do anything but make for frustration.
PLEASE broman... the guy may be right but if you dont write dont the actual codes it's like playing 'Telephone' {child's game showing how messages get twisted}
How the hell are we supposed to know what's going on.
I know you think you're telling everything but that's for us to judge, not you. You can be comforted in that you are far from the worst.. you will open the hood
Watch this
From the info we now have, I think it's a good bet there is a fuel leak in the upper plenum.
From what you know it''s imperative you get the problem solved soon or quit driving it.
Now what...
Old Oct 3, 2011 | 02:10 PM
bromanjr's Avatar
Originally Posted by pettyfog
Sidebar:
I agree.
Watch this
I also agree, Who is "we" and "us"? Aren't I part of we and us?
Now what...
That is what I said.
Why would checking fuel pressure and leak-down not be a logical next step?
Old Oct 3, 2011 | 02:21 PM
randyw's Avatar
Pettyfog, thanks i was just reminded why i hate chevys and chevy ppl, the cars are pos's and the chevy ppl well are pos smartasses, **** off. No advice has been given let alone ignored. I now see i choose the wrong forums to turn to during my time in need, so i will move on to somewhere else that's less of a joke and more helpful, where to find something like that dealing with chevy bitches? **** u **** this forum **** chevys oh and one more time **** u.
Old Oct 3, 2011 | 02:34 PM
grizzstang's Avatar
grizzstang is on a distinguished road
With your attitude I would think getting help will be impossible. Good luck with your problem.
