Trailer wiring 2003 S-10 Blazer 4x4
Old May 25, 2008 | 12:32 AM
Extreme2003's Avatar
Extreme2003 is an unknown quantity at this point
Default Trailer wiring 2003 S-10 Blazer 4x4
Newbie here. I was trying to connect my trailer wiring to by splicing into the existing wiring harness using a 4 flat connector. My left turn signal which should be yellow, does not seem to be working. I troubleshot to the first disconnect under the body and that is fine, so I figure it goes further up. Any ideas? This vehicle has never towed. Now if it is a wiring fault from GM, will they honour it and replace it? Thanks.
Old May 25, 2008 | 11:57 AM
WolfPack's Avatar
Default RE: Trailer wiring 2003 S-10 Blazer 4x4
It's probably disconnected in the engine bay. And I don't see GM fixing it unless you've got an extended warranty....even then....probably not.
Old May 25, 2008 | 12:48 PM
Thanks, where in the engine bay would I find the bundle? All the other lights for the trailer, just the left turn signal. Grrrrr.
Old May 29, 2008 | 06:23 AM
m00n1957's Avatar
m00n1957 is an unknown quantity at this point
i'd take a test light and make sure you got power to trailer plug with trun signal on first. does left turn signal work on truck ?
Old May 29, 2008 | 03:25 PM
black powder's Avatar
black powder is an unknown quantity at this point
ORIGINAL: Extreme2003
had the same problem as you ..on your right hand front fender you have a fuse box ..open it and change the fuse ..
Old Jul 24, 2008 | 02:52 AM
Thanks, yes my normal signal lights work, just the trailer connector left signal is not working. Thanks black powder I shall look into that tomorrow.
Old Jul 26, 2008 | 07:11 PM
toaks's Avatar
toaks is an unknown quantity at this point
If you have a Multimeter you should check the voltage, if you dont have one then go to radio shack and get one for 10 or 20 bucks. Disconnect your trailer from the truck connector. Turn on the right turn signal and check the voltage between the right (green) post and the ground. Put the left signal on and check the voltage on the yellow, it should give the same voltage as the green. If both are reading the same voltage then you have a problem with your trailer wiring or bulbs.
Old Aug 19, 2008 | 12:20 AM
Thanks folks, I feel stupid, it was a fuse. I didn't know each side had it's own fuse, let alone the trailer lighting had its own fuse. It was one of the 10 amp fuse under the hood/bonnet. Thanks Blackpowder!
B-Blazer
Jun 10, 2014 09:47 PM
geo
Dec 6, 2013 07:05 AM
phxjosh
Oct 30, 2013 10:03 AM
Rups63
Apr 7, 2006 11:14 AM
trapper_canada
Aug 15, 2005 11:33 PM
