trailer wiring problems
Old Jun 14, 2010 | 04:29 PM
jnail's Avatar
jnail is an unknown quantity at this point
Default trailer wiring problems
I have the factory installed trailer wiring hooked up on my 98 blazer. But I lost the left turn signal, and there is no power to the yellow wire when the turn signal is on. I tried tracing the wires back, and can see them dissapear somewhere above the frame rail.
does anyone know where these wire hook up to on the other end?
what else should I check?
Old Jun 14, 2010 | 06:33 PM
abig84's Avatar
I had a newer ranger and it actually had its own fuses for each wire to the trailer lights.
There should be power before the split cause your tail lights and brake lights are on the same wires. So either the splitter is bad or the wire. I would just splice off the tail light turn signal wire and call it a day if you can't figure it out
Old Aug 29, 2010 | 05:16 PM
geesspots's Avatar
geesspots is on a distinguished road
the fuse block under the hood will have separate fuses for all the trailer wiring check here first. just keep in mind that a fuse blows for a reason maybe redo the ground on the trailer this tends to be a common reason.
phxjosh
Oct 30, 2013 10:03 AM
krosebud84
May 11, 2007 04:54 PM
The Franchise
May 31, 2006 12:28 AM
Rups63
Apr 7, 2006 11:14 AM
trapper_canada
Aug 15, 2005 11:33 PM
