Trailering
RE: Trailering
would that be like a "drop in" upgrade or would i have to go to a shop to have them do it?
RE: Trailering
It is quite easy to do yourself. The grill comes off quite easily giving you all kinds of access for mounting it. You may need a drill for some mounting holes, but you can use the tie straps that go thru the condensor and radiator which are pretty easy. There is a plastic panel that can also be cut to allow for the hoses to pass thru using as short of a hose as possible. You may need to pick up some more 3/8" hose for the installation, most kits don't include enough.
RE: Trailering
I agree with kyle on doing the tranni cooler upgrade, my dad even suggested that to me when I mentioned towing a chevy fullsize truck across phoenix in the summer but I just went and towed it anyway and it did fine, but I would upgrade to a tranni cooler!!
