Tranny crossmember
Old Apr 1, 2008 | 09:53 PM
lynnmcd's Avatar
lynnmcd is an unknown quantity at this point
Default Tranny crossmember
My passenger side of rear tranny crossmember is very rusty and looks as if it could break. I searched for ways of replacing with no luck. I suspect I should put a jack under the transmission case before unbolting the 4 bolts. Any help?
Should I get one from salvage yard?
Old Apr 2, 2008 | 05:42 AM
Default RE: Tranny crossmember
Does it just look rusted or is it rusted through? Have you used a screw driver to 'sound' the steel? These things rust from time to time, but it is only surface rust much like the different sections of the frame.
What is it that you are driving? This information is necessary to move this post into the proper generational section. We are trying to clear out the Gen Tech section (as the post at the top of this section details).
Old Apr 2, 2008 | 06:40 PM
lynnmcd's Avatar
1999 Bravada
The crossmember is rusted to point of having hole on the ventral portion in one 6 inch section of passenger side. The steel is flaking. Any suggestions on removing (jack under
transmission for support?)
Old Apr 2, 2008 | 07:49 PM
You can jack under either the transfer case or the transmission. If under the transmission pan, use a board to span the width of the pan for added support. Then unbolt.
*Moving to 2nd Gen Tech*
Old Apr 2, 2008 | 08:22 PM
lynnmcd's Avatar
Having a hard time finding one-- will a Chevy S10 blazer
transmission cross member fit without cutting holes,etc?
Old Apr 2, 2008 | 08:35 PM
Any '98+ S-Series 4wd 4dr SUV will work. So any '98+ 4wd/Awd 4dr Blazer, Jimmy, or Bravada.
*EDIT* I didn't think I needed to list that it must come from an Automatic equiped vehicle as I thought that would be known already. Basically any S-series suv that matches your specs (4dr, 4wd/awd, auto).
94blueknight
Apr 3, 2008 11:45 AM
lynnmcd
Suspension Tech
Apr 3, 2008 08:47 AM
ben_b
Aug 3, 2007 01:13 AM
mdemers2006
Jul 26, 2007 06:41 AM
mars004
Dec 13, 2006 02:04 AM
