trans oil and filter change
Old 09-25-2013, 11:36 AM
Thager's Avatar
Thager is on a distinguished road
mine came off easy, didnt have to jack it up , it drained about 5L of oil .
the pan fits fairly tight to the valve body so im not sure where you would put a drain plug.
Old 09-26-2013, 05:53 PM
jimspahr@msn.com's Avatar
Since the Silverado/Sierra uses the 4L60E trans like the Blazer/Jimmy, I was hoping the OEM Silverado pan with a drain plug could be swapped in to the Blazer with no problem. The full size trucks sometimes offer a larger capacity pan as well. That would be nice, but with clearance an issue , that larger capacity feature is probably out. It could be an option for the 2WD version of the Blazer?
Old 09-27-2013, 12:08 PM
John L. Grevious Jr's Avatar
John L. Grevious Jr is on a distinguished road
so what is the best ATF to buy and filter? is there some sort of cleaner to clean the transmission out also?
GMdesigner
10-29-2013 02:26 PM
chris015
06-08-2012 12:37 PM
badpoor
01-07-2011 06:35 PM
doobie98dailydriver
03-24-2010 10:40 AM
shawnwarvet
08-07-2007 08:48 PM
Quick Reply: trans oil and filter change
