Trans temp guage
Old Aug 4, 2012 | 07:38 AM
All 4L60E's have it. The sensor clips to the transmission filter. The PCM alters shift points when the fluid begins to overheat, commonly referred to as "limp mode". Easiest way to monitor the fluid temp it is with a scan tool.
Old Aug 4, 2012 | 10:47 AM
gitch93's Avatar
gitch93 is on a distinguished road
If they are equipped with a factory temp gauge where on the wiring harness do I splice into for a accurate reading. I got a 2000 jimmy slt
Old Aug 4, 2012 | 11:46 AM
They are not equipped with a temperature gauge, only a sensor. The "gauge" is the scan tool. The sensor is a thermistor, a resistor that changes resistance with temperature. The PCM monitors the voltage, converts it to temperature, and alters the shift pattern accordingly, when necessary. You can monitor the fluid temperature with a transmission capable scan tool. Splicing into the sensor wire may affect how the PCM interprets the data, not a good idea.
zakm0n
Jan 9, 2011 07:31 PM
pmezo
28
Nov 6, 2010 04:30 PM
bertrenolds
Dec 19, 2008 07:45 PM
myronhntr80
Mar 6, 2008 07:58 PM
docta J
Nov 18, 2007 01:25 PM
