transfer case
Old May 31, 2008 | 07:09 PM
pdl122000's Avatar
pdl122000 is an unknown quantity at this point
Default transfer case
Please help my wife owns a 99 blazzer, I need help with what type fluid to run in transfer case and how much and where to fill. thanks for any help.
Old May 31, 2008 | 07:13 PM
Default RE: transfer case
We need a bit more information from you. Do you have the Auto4wd option on your dash switch? If you do, then you require AutoTrak 2 fluid. I can't remember exactly how much fluid off the top of my head, but I know I have posted it in other threads in the past.
If you do not have the auto 4wd option, then regular Dexron ATF (automatic transmission fluid) is the factory fill.
Old May 31, 2008 | 07:45 PM
pdl122000's Avatar
Thanks swartlkk, I do have auto 4wd. I had the transmission rebuilt back in january, went to change the oil today and noticed fluid every where. not trans cause its full. I know where the drain plug is, butt not the fill. thanks again.
Old May 31, 2008 | 08:11 PM
The fill plug is above the drain plug. The fluid in your transfer case should be blue in color.
If it is red, then you are getting transmission fluid past the front seal on the transfer case.
Old May 31, 2008 | 09:14 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
The capacity depends on wether you have the NVG or the Borg Warner. The NVG is close to 2 qts if I recall and the Borg Warner is like 1.25qts. Either way you will need at least 2 qts. The NVG is magnesium and has plugs that look like a bolt with a big head on them. The Borg Warner is aluminum and has plugs that you put a socket wrench extension into.
Old Jun 1, 2008 | 02:03 PM
pdl122000's Avatar
thanks everybody, hatted to sound dumb, butt never had mess with transfer case.
Flyfishen
Jun 18, 2019 11:22 AM
bensaintonge
Dec 3, 2013 08:14 AM
bob2231
Nov 6, 2005 04:40 PM
loscochinos520
May 28, 2005 11:32 PM
buckwheat
Jan 6, 2005 04:59 PM
