Transfer case leaks
Old Oct 16, 2020 | 07:46 PM
Nate89's Avatar
Nate89 is on a distinguished road
Default Transfer case leaks
My transfer case seems to be leaking from the joint between the two half. Its just rtv gasket there doesn't last forever. Is it possible to split the t case reseal it without removing it completely. I'm just tired of chasing leaks and I don't have a lot of time or help to remove.
Old Oct 17, 2020 | 07:42 AM
LannyL81's Avatar
You know....I do not remember ever reading about a transfer case leaking other than the input seal or the case got cracked from an impact. In the case of the input seal failure, transmission fluid would fill the T-case and I think come out via a vent. Is the stuff leaking red or blue?
Old Oct 17, 2020 | 05:53 PM
Nate89's Avatar
Lanny its clear, yeah the skid plate shows no signs of impact why I think the rtv is just old.
Old Oct 17, 2020 | 08:30 PM
LannyL81's Avatar
Clear?....the Chevy/GM transfer case fluid is blue, referred to as "Smurf Juice" Of course ATF is red.....but clear??....now that is really odd! Only fluid I know of that is clear is water. Very puzzled.
Old Oct 18, 2020 | 12:08 AM
go chevy's Avatar
Clear??? That is strange indeed! I am beyond curious now as 2 follow along until you figure it out...
Old Oct 18, 2020 | 12:34 PM
Nate89's Avatar
If it was previously filled with gear oil not atf or gm fluid it would be yellowish clear guys. Second owner to this 18 yr old vehicle i don't know all the stuff thats been done.
Old Oct 19, 2020 | 08:44 PM
LannyL81's Avatar
Yep...fully understand the "who knows what the previous owner" has done. Good to hear that it is NOT ATF as that would make a short life of the transfer case. Now if standard gear lube was used......???
Looks like you get to be the first to see if you can separate the case and fix.
Jason Schwesinger
Nov 3, 2016 12:35 PM
98jimmyengine
May 4, 2014 08:49 PM
jlboots
Sep 20, 2012 05:08 PM
soky25
Aug 26, 2010 02:58 PM
daron gorichar
Sep 20, 2009 10:57 AM
