Transfer case switch Connector
Old Dec 30, 2012 | 10:47 AM
stubbe's Avatar
stubbe is on a distinguished road
Default Transfer case switch Connector
I have a 1996 Blazer and I have been having problems with the four wheel drive. found that the switch on the T' case was bad and replaced it. Now I have a Vacuum leak at the switch. 3 pin vacuum connector is bad. I am having trouble finding a replacement. Any help finding a part number or part would be a great help.
Thanks
Steve
Old Dec 30, 2012 | 02:19 PM
aa21830's Avatar
aa21830 is on a distinguished road
Is the connector too loose around the prongs? If so wrap some duct tape around the Prongs to make them larger.
Old Dec 30, 2012 | 02:48 PM
m0perale's Avatar
m0perale is on a distinguished road
Edit: Nevermind! See below.
Old Dec 30, 2012 | 03:14 PM
The connector should be OE part number is 15537463 according to NalleyGMC.com's Parts Diagram & listing (click on the PN for the diagrams). You might want to confirm that with your local GM dealer before ordering as some of the other diagrams seem to conflict a bit, but according to the image below, it does appear to be the correct PN:
One of the diagrams shows some additional 'connectors' that are likely hard plastic lines to adapt between the rubber mutli-port connector PN-15537463 to the 3 individual vacuum lines. You can probably make them yourself out of normal hose barbs often available in assortment packs at your favorite autoparts store.
Attached Thumbnails Transfer case switch Connector-%24-kgrhqv-n0e9clwpyrfbpfhm66hiw%7E%7E60_12.jpg   Transfer case switch Connector-%24-kgrhqf-pse9elob-oqbpfhnhieiw%7E%7E60_12.jpg
Old Jan 1, 2013 | 02:01 PM
stubbe's Avatar
Default 3 prong connector
Thanks swartlkk for the help.
That is the connector and have one on order.
Steve
Rathbone
Mar 1, 2023 06:11 PM
man0steel
Aug 17, 2018 07:14 AM
boudreaux55
Jun 4, 2018 06:39 PM
rockp2
May 14, 2018 08:06 PM
SockJock
Mar 4, 2009 11:55 AM
