Transfer Case Vaccum Lines
Old Apr 9, 2012 | 12:07 PM
75travis75's Avatar
75travis75 is on a distinguished road
Default Transfer Case Vaccum Lines
hello all! ive been all over this forum and i cant find an answer for my 97 chevy blazer ls...my problem is that theres three hoses coming off the transfer case and im not sure where one goes.the one im questioning is the line that Y"s just above the transfer case.it was just hanging there.im hoping its the vent hose.then theres the two other hoses and im not sure but i think one goes to the vaccum ball drivers side,one goes to the 4wd actuator under battery tray,then the one in question i think is the vent hose.does anyone know where i can find the link that will tell me which line comes off of what and goes to what?
Old Apr 9, 2012 | 01:34 PM
aa21830's Avatar
aa21830 is on a distinguished road
You're correct - vent hose is the 3rd line. Here's a diagram. Where it says "Vent to atmosphere", that is a line that goes up under the hood and is attached up near the firewall on the passenger side (if I remember correctly).
The other two lines, you are correct, one goes to the 4WD actuator and the other one connects to a "tee" near the vacuum ball (does not go directly to it, though).
Old Apr 9, 2012 | 01:56 PM
75travis75's Avatar
But how do you know which ones goes to the actuator,ball and vent...from the transfer case? i know one of the lines that comes off the transfer case Y's and thats the one im thinking is the vent but not sure
Old Apr 9, 2012 | 02:27 PM
Check out this thread from the Tech Article (DIY) section:
4wd Front Axle Clicking When in 2HI - Goes Away when in 4HI/4LO
It should have a diagram showing which port is which on the vacuum switch referencing the clocking pin. I say should because I cannot view my photobucket pictures from work so I am working from memory here.
Old Apr 9, 2012 | 05:10 PM
aa21830's Avatar
Here ya go:
The plastic alignment pin is the colored lines. So it would match up with the rubber 3-way junction thing like this (looking into it, where the black dot is the hole where the alignment pin goes into):
Old Apr 9, 2012 | 05:46 PM
LannyL81's Avatar
Deleted
Old Apr 9, 2012 | 08:44 PM
That's not the one I was thinking of. I must have moved it in photobucket some time ago so it wasn't showing up. This is it:
But you already put in your copy of the same thing.
Old Apr 10, 2012 | 07:27 AM
75travis75's Avatar
Thanks Fellas....Great help!!!!!
Flyfishen
Jun 18, 2019 11:22 AM
sporty982000
Aug 24, 2014 07:45 PM
Pobey
Nov 4, 2010 11:24 AM
gmcinister
Jul 28, 2010 08:39 PM
wader
Feb 9, 2009 02:05 PM
