Transmission?
Old Jul 29, 2009 | 01:09 AM
xCHIPx's Avatar
xCHIPx is on a distinguished road
Default Transmission?
Whens a good time to change the fluid in it?
Or do you even have to? I dont know anything about transmissions.
Old Jul 29, 2009 | 01:17 AM
bandidolenny's Avatar
Now is a good time... I recommend doing a full fluid flush every 30k to 50k depending on how you use the vehicle. Every 100k if you go with a fully synthetic fluid.
Old Jul 29, 2009 | 01:23 AM
xCHIPx's Avatar
Ahh okay Im goin to do it fast then.
I had a friend say change th filter to? Should I?
What do i need to change it?
Old Jul 29, 2009 | 03:29 PM
If you have to drop the pan, replace the filter while you are in there. You might as well. If you install a drain plug in the pan, then you should not have to change the filter again. Remember, an automatic transmission is a closed system. The only components that can plug up the filter are bits and pieces of the transmission itself.
Old Jul 29, 2009 | 04:24 PM
xCHIPx's Avatar
Okay thanks.
What kinda fluid do I buy and filter?
Old Jul 29, 2009 | 04:49 PM
Get Dexron 6 fluid. It is the newest synthetic available and is backwards compatible to Dexron 3. As far as the filter goes, they are all basically the same.
Old Jul 29, 2009 | 11:31 PM
xCHIPx's Avatar
Okay cool thanks for the help.
GloryImSaved
Jul 17, 2009 09:05 PM
sfesenko
Dec 12, 2008 10:03 AM
