transmission issue maybe?
Old Jan 22, 2012 | 11:16 PM
NicholasTeal's Avatar
NicholasTeal is on a distinguished road
Default transmission issue maybe?
I got into my 98 blazer this evening and tried to get it going to pick up my girlfriend from work. The truck was parked in a somewhat icy area. It was able to go in reverse a little, then when I shifted into drive it wouldnt move. I tried putting it into 4 hi, but it didnt want to go. I tried 4 low with the same result. I tried it again and it seemed to go in. Then the lights on the 4wheel switch all went out. When I pressed on the gas it acted like a car with a slipping clutch, badly slipping, except I have an automatic. The rpm would go up to 3000 just to get it up to 5mph. It was almost like it was stuck in 3rd gear. I have not tested anything yet, as it is dark outside. Any ideas where I should start tomorrow?
Old Jan 23, 2012 | 05:16 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
Did you happen to notice if the speedometer was working ? If it wasn't then it's the vehicle speed sensor .
Old Jan 24, 2012 | 10:29 AM
The speedo was working. In drive I was able to get it up to about 10mph. In drive it doesn't shift. I can manually shift it between 1 2 or 3 via the shifter, but otherwise it doesn't shift.
NowhereMan1966
Sep 4, 2013 10:43 PM
GMdesigner
Jun 22, 2007 12:02 PM
USMaverick101
Nov 17, 2006 04:06 PM
jadewolf32
Mar 1, 2006 02:48 PM
Jhop16
Feb 4, 2006 10:39 PM
