Transmission..next step HELP
Old Oct 12, 2010 | 06:18 PM
BlazerDarrin's Avatar
BlazerDarrin is on a distinguished road
Default Transmission..next step HELP
1997 Chevy Blazer 4.3 4x4 automatic. Had the typical solenoid issues when bought. I replaced all solenoids and wiring harness inside. Cleared all codes and drove off. 10 minutes later ALL codes returned, stuck in the 2-3 mode. Had my friend clear all codes with a Snap On brick and drove it again. 15 min. later all codes, and stuck in 2-3 again. The solenoids were all new and wiring was also. Pan was clean. I am at a loss. Also, key sometimes sticks. I am pulling my hair out trying to understand this. All solenoids fit snug with no looseness. When it works it works perfectly. I cleared the codes this morning and then unhooked the battery, drove it 30 minutes before it did it again. Could the ignition switch or the neutral safety switch be doing this to it? I just can't believe it is the solenoids again.
Old Oct 12, 2010 | 07:07 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
Getting any codes? Jerry
Old Oct 12, 2010 | 07:13 PM
Sounds like it could be the ignition switch. Have you tried to monitor the power to the solenoids through the 'trans' fuse?
Old Oct 12, 2010 | 08:12 PM
It throws codes. My scanner says what the code means so I didn't write the codes down but, TCC solenoid, shift solenoid A, shift solenoid B, etc..
How would I monotor thru the fuse?
Old Oct 12, 2010 | 08:49 PM
From my experience, thinking you've got some 700 codes-the ignition switch is looking like the odds on favorite. Jerry
Old Oct 12, 2010 | 08:55 PM
Getting one tomorrow. I have to believe it is that. The key hanging up, all NEW solenoids and harness, new fluid and filter.....Just seems the way to go.
Old Oct 13, 2010 | 07:32 AM
Connect a multimeter to a suitable ground and then connect the positive lead to either side of the trans fuse, leaving the trans fuse installed. Then drive it. You should have +12V in run.
Old Oct 13, 2010 | 10:27 AM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
When do this , what setting do you put the multimeter on?
Old Oct 13, 2010 | 10:30 AM
DC Voltage...
linsgm
Oct 30, 2013 03:56 AM
chevyblazer9588
Nov 20, 2012 10:40 PM
poertsch
May 3, 2012 06:12 PM
rudd21
Nov 12, 2011 03:49 PM
toaks
Detailing
Aug 26, 2008 11:44 AM
