Transmission Overfill causing issues?
Old 04-03-2014, 02:56 AM
Naydog101's Avatar
Naydog101 is on a distinguished road
Default Transmission Overfill causing issues?
Mid Feb I took my blazer into BigO for maintenance and check up. (Tax return) one of the things I had them do was check the tranny. When all was done everything checked out fine. On April 2nd while driving there was a sudden jolt/drop feeling like it just had the hardest time shifting from 1st-2nd. I started listening and heard a whirling noise as I speed up (sounded like and old time police siren) also heard it while idle. There was no smell no visual problems just shifting rough from 1st-2nd and the whirling sound. Upon stopping I checked the tranny fluid and man is it over filled, plus after I checked that and oil the tranny wouldn't engage Reverse? Oil lvl was fine and colored fine, and tranny fluid was light and smelled fine just overfull. Can being overfull cause these symptoms? Cause it not to engage reverse? I didn't drive it much more and only 30 MPH after this all started for fear of damage. If I drain some fluid is there a good chance of being fine or does it sound like I'm screwed and either the torque converter or tranny or both are shot?
Old 04-03-2014, 03:38 AM
LannyL81's Avatar
LannyL81 is on a distinguished road
when you check the trans fluid, was the vehicle on level ground? Did you let it sit and idle for 5 minutes before checking? Otherwise you will get a false reading.
Overfilling will cause the trans fluid to foam and yes I think this could cause engagement problems.
Only way I know of to remove a little bit of fluid is to siphon it out through the dip stick tube as there is no drain plug on the trans pan unless an aftermarket one has been installed.
With the trans cold, siphon out half a quart and see if there is any difference and then recheck level.
Old 04-03-2014, 06:58 AM
Naydog101's Avatar
Thank You for ur reply and the little hope u have given me. To answer your questions, Yes the vehicle was level and it had been running for 15+ min + driving at 30mph before I checked so it should have been plenty hot. I had the same idea for getting fluid out and will try it in a few hours when the sun comes out.
Old 04-03-2014, 09:41 AM
Tajohns34's Avatar
How many miles are on it?
Old 04-03-2014, 10:27 AM
Naydog101's Avatar
Originally Posted by tajohns34
how many miles are on it?
225500
Old 04-03-2014, 12:44 PM
jpimp's Avatar
jpimp is on a distinguished road
I'd guess it wasn't due to being over filled...I think the trans would puke it out of the breather vent if it was too full...my guess is...some other problem...likely internal.
Old 04-03-2014, 01:12 PM
Tajohns34's Avatar
that is a lot of miles to get out of the original transmission. You could try what I did with my k1500. Got the trans flushed and added a secondary cooler for about $40. I got me another year out of the trans before it completely died.
ComputerNerdBD
TrailBlazer GMT360/GMT370 (2002-2009) Tech
05-13-2013 06:24 PM
RockyMountainHermit
06-16-2012 07:33 AM
ixinitroixi
04-26-2012 11:13 PM
Shelly10589
12-17-2011 09:20 AM
chris.one
02-01-2007 02:49 AM
Quick Reply: Transmission Overfill causing issues?
