Transmission Problem?
Old Dec 10, 2008 | 09:16 PM
bigguy8786's Avatar
bigguy8786 is an unknown quantity at this point
Default Transmission Problem?
Ok so this might seem like a stupid question but I think my blazer is broken AGAIN!!!!!! So whenever i put the car in drive it seems to go quite a bit forward without pressing the gas, I know thats what its supposed to do while in drive, but it seems as if its going forward like the gas pedal is pressed a little bit but I have not touched the pedal at all if you know what i mean. Then when I start going it jerks really hard when switching from first to second gear and then I think it just stays in 3rd gear because I will be going about 40 mph and its reving at like 3500 rpms when usually it would change gears. To me it seems as if this is a transmission problem but I have no idea when it comes to under the hood. The reason I ask is because this is a brand new transmission that was put in about 2 months ago and is still under warranty. ANY THOUGHTS?? Thanks
Old Dec 10, 2008 | 09:19 PM
WolfPack's Avatar
Default RE: Transmission Problem?
Sounds like a torque converter problem, not a tranny problem. Have you checked your tranny fluid though?
AND if its under warranty, why even hesitate to take it back?
Old Dec 10, 2008 | 09:47 PM
bigguy8786's Avatar
No I havent checked the fluid yet because it just started happening about 3 hours ago and its been raining all day in charlotte....and yeah i'm definitely taking it back to the shop tomorrow for them to look at it when I get a chance....I'm just hoping I can make it to work and to the shop which is a half hour away
Old Dec 10, 2008 | 10:15 PM
WolfPack's Avatar
Try gunning through the gears with a little more throttle. Mine used to hold some shifts before I realized I had a tranny leak and a little extra goose on the throttle convinced it to shift...it was the light throttle shifts that gave me trouble.
Old Dec 11, 2008 | 08:31 AM
bigguy8786's Avatar
Thanks Wolfpack for your help but I found the problem when I was driving to work this morning. It was doing the same thing so I decided to see what happens when I put it in 4wd so I go to hit the button and I saw that it was in 4wd low. So I told you it was a stupid question...must have bumped it or something when leaving school last night...anyways thanks again for the help.
Old Dec 11, 2008 | 03:32 PM
WolfPack's Avatar
Haha that'll do it
DBo42098
Aug 25, 2009 05:11 PM
GloryImSaved
Jul 17, 2009 09:05 PM
sfesenko
Dec 12, 2008 10:03 AM
Cuppy
Jul 21, 2006 11:25 PM
jermag24
Engine & Internal
Jan 6, 2005 10:56 PM
