Transmission question ZR2
Old Dec 30, 2014 | 08:14 PM
NCSurvival's Avatar
NCSurvival is on a distinguished road
Default Transmission question ZR2
Going up my steep driveway in the 99 ZR2 Blazer every gear will pull the truck up except 2nd. When I let my foot off the brake, it doesn't roll back when in 2nd. But every other gear will pull and roll back. But it does fine in Overdrive. What gives?!
Old Dec 31, 2014 | 09:06 AM
"every gear will pull the truck up except 2nd"
Does the vehicle move forward if you push the gas pedal farther down? Keep in mind you are starting out in a higher gear so you'll have to push harder on the gas.
At a stop, when you select any forward gear except "2", the transmission starts out in first gear. When you select "2", it overrides the default of first gear, and it starts out in second gear. What you're experiencing is normal.
Old Dec 31, 2014 | 03:41 PM
Gregg64's Avatar
Gregg64 is on a distinguished road
Why, would you be trying to pull up a hill in second gear in the first place. Either let it do it's thing automatically or use the gears in the proper order or it wont work correctly for very long.
Unless you have a full manual valve body you can not select any gear you want and it work correctly. You must use them in the proper sequence.
Old Dec 31, 2014 | 03:51 PM
Starting out in second gear gives you better traction climbing hills on snow, ice, getting un-stuck, etc. Less torque to the wheels so they don't break loose as easily. That's why they give you the option. Been that way for YEARS on auto transmissions, the owners manual explains it.
Old Dec 31, 2014 | 07:18 PM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
Say it ain't so.....
Old Jan 1, 2015 | 08:24 AM
NCSurvival's Avatar
It moves forward in all manual selections (uphill) except for 2nd. I tried giving it more gas and nothing happened.
Old Jan 1, 2015 | 08:26 AM
NCSurvival's Avatar
My rear brakes started grinding metal to metal with no warning, so to avoid compounding the problem, I was manually downshifting for an engine brake effect just to get me home so I could fix the brakes.
Bberry20
Feb 25, 2010 09:28 PM
Spectreblazer
Feb 13, 2010 04:59 PM
Logan
36
Dec 6, 2009 07:41 PM
PJT2007
Oct 7, 2008 10:47 PM
Logan
Lifting Tech
Sep 18, 2008 11:44 AM
