Trip Odometer not working (Analog)
Old Mar 14, 2020 | 09:20 AM
BorderCougah's Avatar
BorderCougah is on a distinguished road
Default Trip Odometer not working (Analog)
'97 Blazer, Analog cluster, not Digital.
My Trip Odometer I noticed just stopped working today after resetting it when I filled up some gas. For the record, my main odometer still works and spins fine. It's just the re-settable trip odometer. Hitting the reset button a few more times did nothing. Everything else on dash works fine.
Reading up, I'm told the old Analog odometers can have gears that break. Could this be the case with mine, and would it be possible for just the trip to break and not the main?
Thanks.
Old Mar 14, 2020 | 04:00 PM
I wouldn't be surprised that a gear broke. They are made of plastic and with the reset button mechanism, it is quite a jolt to them. But you could likely get what you need from a gauge cluster found at a wrecking yard and repair it.
Old Mar 14, 2020 | 05:43 PM
So it is some plastic gearing that likely broke? Cool. I'll look into that then at a yard next chance I get. Much oblidged!
Old Jun 12, 2020 | 10:39 AM
Update:
Not sure what happened but the trip odometer started working again one day.
Same day it started working, I had replaced the Neutral Safety Switch and resoldered some broken wires that went to the NSS plug.
Not sure if maybe one of those wires being broken was the culrpit. But that was a couple months ago and it's been working since.
tstaller2005
Mar 5, 2012 12:47 PM
richphotos
Feb 3, 2012 02:53 AM
a-dub
Mar 7, 2009 07:19 PM
Bl4z3r
Feb 10, 2009 08:39 PM
