Trouble code po753
Old Jul 16, 2010 | 06:15 PM
brians1bad72's Avatar
brians1bad72 is an unknown quantity at this point
ok, I will give it a shot and report back, thanks for your help.
Old Jul 16, 2010 | 08:19 PM
nemesis's Avatar
nemesis is on a distinguished road
The most likely cause of this condition may be a loss of voltage to the transmission solenoid power supply circuit. This condition may also be the result of an incorrect installation of an aftermarket electronic device such as a remote starter or alarm system. Otherwise check the fuse on the left side I.P. fuse box WHEN its acting up, if no voltage at the fuse, replace the ignition switch, its somewhat of a common problem.
Old Jul 16, 2010 | 08:27 PM
I didn't mention that because that condition typically will trigger other codes for the other things also powered off of the CLSTR fuse as shown in the wiring schematic for this code. Worth checking into though.
Old Jul 16, 2010 | 09:00 PM
nemesis's Avatar
sorry dude, your right, usually it sets multiple low voltage codes also. I didn't mean to steal your thunder, lol. Its such a simple test tho, I've wired in a test lamp while driving and waited for it to act up.
I believe I've seen that harness get pinched between the bell housing and block too
Old Jul 19, 2010 | 11:34 PM
Ok I unplugged the connector above the trans. pan and checked for power at the light green wire with a test light, key on engine off. No power, any suggestions.
Old Jul 20, 2010 | 12:05 AM
nemesis's Avatar
the light green wire is a ground from the PCM, you need check the pink wire for voltage at terminal E also.
Old Jul 20, 2010 | 06:19 AM
Bingo!
Old Jul 21, 2010 | 12:41 AM
I was just looking at the wiring diagram your right I need to check the pink wire, I will do that in the mourning and report back thanks.
Old Jul 21, 2010 | 11:29 AM
I checked for power at pin E pink wire and I have power. I checked it with a test light, it illuminates, should I check for voltage, should it have 12 vlts. or just power.
Old Jul 21, 2010 | 01:14 PM
You need 12V.
