Trouble code po753
The most likely cause of this condition may be a loss of voltage to the transmission solenoid power supply circuit. This condition may also be the result of an incorrect installation of an aftermarket electronic device such as a remote starter or alarm system. Otherwise check the fuse on the left side I.P. fuse box WHEN its acting up, if no voltage at the fuse, replace the ignition switch, its somewhat of a common problem.
I didn't mention that because that condition typically will trigger other codes for the other things also powered off of the CLSTR fuse as shown in the wiring schematic for this code. Worth checking into though.
sorry dude, your right, usually it sets multiple low voltage codes also. I didn't mean to steal your thunder, lol. Its such a simple test tho, I've wired in a test lamp while driving and waited for it to act up.
I believe I've seen that harness get pinched between the bell housing and block too
