truck bucking
Old May 14, 2013 | 04:05 PM
turbotype87's Avatar
turbotype87 is on a distinguished road
Default truck bucking
Hey guys, I have a 2002 chevy blazer ZR2 Model the problem i am having is with the vechicle jerking and bucking as if its not getting enough fuel. I ran a pressure test and its getting the recommended pressure by factory specs. between 60-66psi. Its at 62psi.Fuel pressure regulator, New fuel pump put in last year. I just changed my ABS Control Module it was shot. I was thinking maybe the speed sensors couldn't determine what speed the vechicle was going maybe causing the vechicle to buck or jerk? OBD wasn't showing any codes. Any help will be appreciated. thanks Scott
Old May 14, 2013 | 05:41 PM
liljoejoe54's Avatar
liljoejoe54 is on a distinguished road
Could be something as simple as a tune up. Spark plugs, wires, distributor cap, and rotor might have to be changed.
Old May 14, 2013 | 06:24 PM
swanman35's Avatar
swanman35 is on a distinguished road
Mine was doing it, then I changed spark plugs, and cap and rotor And I runs well. don't get a cheap cap and rotor, ac delco. my cheap one needed replacing after a month, luckily it has a 5 year warranty.
Old May 15, 2013 | 04:59 PM
Thanks for the feedback, I had a tune up done about 2yrs ago. I guess its that time again.
Old May 16, 2013 | 06:10 AM
swanman35's Avatar
Check in your air box too. Could be something in there blocking air.
Sparky
Jul 16, 2011 10:14 PM
maxell12342003
Dec 21, 2009 04:32 PM
corvette535
Mar 10, 2009 05:46 PM
ChurchvilleMcBlazer
Jun 24, 2008 08:46 PM
sb355
Feb 20, 2006 03:29 PM
