truck cranks but won't start
Old Jan 8, 2008 | 05:55 PM
99whiteblazer's Avatar
99whiteblazer is an unknown quantity at this point
Default RE: truck cranks but won't start
Turn the key pump turns on gage reads 61psi. Wait acouple of seconds hear the pump turn off and the gage reads zero. Take the key out and the gage goes back up to 61psi. Did i do this test right and if so is the pump good or bad?
thanks
Old Jan 8, 2008 | 06:08 PM
Sounds like you have a pressure line leak somewhere near the tank. If the pump can't keep up with the leak and the requirements of the engine, the engine performance will suffer.
You really need to figure out where it is leaking from up on top of the tank. You'll have to atleast partially drop the tank to take a look. Do yourself a favor and pick up a mechanics mirror. I have about 3 different sizes/shapes and each one is worth 10x its weight in gold!
Old Jan 8, 2008 | 06:17 PM
Is it possible to have a fuel leak even if i don't smell anything. Reason i'm asking is a couple of years ago i had a fuel leak in my honda and the only reason i found it was it stunk up the garage. I'm not smelling fuel from the truck or any signs of fuel on the ground.
Old Jan 8, 2008 | 06:45 PM
Wait a minute here... Ignore my post... That was meant for a PM to someone who had a leak at the top of the tank and for some reason it made it here... Man am I tired...
Anyway, if the pressure is leaking down that fast, then you definitely have a leak. Crappy part is to determine if it is the fuel pressure regulator, you really have to pull the upper plenum off. If you have a mechanics mirror, you may be able to see into the back of the intake after removing the throttle body...
The fuel pressure not drop more than 2 psi after key off. If it drops fast like you describe, there is definitely something wrong.
Rhodes19
48
Feb 15, 2013 09:46 PM
bsbob
Jul 22, 2011 12:48 PM
nyjeepman
34
Mar 15, 2009 07:40 PM
jdbrown66
Nov 19, 2008 03:57 PM
sindy1232
Jul 25, 2008 11:59 AM
