Is this True
Old Jun 10, 2008 | 09:11 AM
gus's Avatar
gus
gus is an unknown quantity at this point
Default Is this True
I replaced the idle control valve on my 97 blazer and someone told me it needs to be reset and that it can only be done by the dealer. Is this true.
Old Jun 10, 2008 | 09:19 AM
Default RE: Is this True
If you disconnect the battery for 10-15 minutes, the IAC position reference will be wiped and reset when the engine is run next. Just start the engine and let it run until idle sets to a constant 7-800RPM for cold, 5-600RPM for hot.
Old Jun 10, 2008 | 09:23 AM
gus's Avatar
gus
Cool thanks. I also replaced the throtle position sensor. Do I need to do anything speacial for that?
Old Jun 10, 2008 | 09:24 AM
Nope.
Old Jun 10, 2008 | 09:33 AM
gus's Avatar
gus
Let me give the whole story. I have a code that says high RPM detected. I changed the IAC, TPS, New timing chain, Cleaned the EGR, new plugs, wires, distributor, rotor, cap, Crank position sensor and it still shows the code. It runs great except for at a stop it rough idles for 3 - 4 seconds and then is fine. During the rough idle, the oilpreasure gauge is going crazy and then it goes normal
Old Jun 10, 2008 | 10:16 AM
test
Old Jun 16, 2008 | 07:02 AM
gus's Avatar
gus
Hey swartlkk, I wanna start with the complete list of what is happenning with my vehicle since I think people are just reading the first post about the IAC. Can I delete this one and make a new thread?
Old Jun 16, 2008 | 07:05 AM
Sure, go ahead. Hopefully I can respond with more than 15-20 words...
mojoman13
Jul 8, 2009 07:12 AM
willjones
Jan 30, 2008 07:54 PM
murfthesurf4
Nov 26, 2007 11:01 AM
2klt
Mar 19, 2007 10:49 PM
the_mind
Headers, Intake, & Exhaust
Jul 22, 2005 06:06 PM
