trunk glass locked
trunk glass locked
need some help? unable to open glass trunk. Motor for trunk seems to be working fine, however rear glass unable to open while lifting. Any tips on troubleshooting this problem?
RE: trunk glass locked
Is the cellanoid popping when you push the button?....
If so, then there may be a latch inside the door which is sticking. Peel off the plastic on the inside of the door and you should be able to access the lock fairly easily. (I think it comes out with two screws)
If not, then you probably have a blown fuse. Check the fuse box under the hood and there should be a fuse for your power mirrors that is also tied into your rear glass.
We had a rash of this exact problem before... Let me see if I can find the post that best describes how to fix it...
Here ya go:
Faulty Rear Hatch
Here ya go:
Faulty Rear Hatch
ruxpin76
08-27-2012 04:34 PM
scosentino88
06-03-2012 07:12 PM
98BlackBlazer
07-22-2006 03:05 PM
