Tune Up Questions
Old Mar 26, 2009 | 07:32 PM
96chevblazer's Avatar
Default Tune Up Questions
Okay I have 96 Blazer w/ the 4.3 powerplant and 193000 miles on her, but she needs a tune up. I have not change the plugs since I have gotten it (83000 miles) and I think I should seafoam it. Should I do anything else?
Old Mar 26, 2009 | 08:47 PM
Plugs, wires, cap, & rotor. Clean the EGR valve and MAF sensor. Install a new gasket on the EGR valve, one with a screened inlet port. Maybe remove and clean the throttle body. Before you do the tune up, do the seafoam.
Old Mar 26, 2009 | 11:37 PM
Swain's Avatar
Swain is an unknown quantity at this point
Check/replace your air filter as well, and a new fuel filter if you haven't recently.
EDIT: Grease up your front end as well! I think these three posts cover a tune up pretty well.
Old Mar 26, 2009 | 11:53 PM
boomtruck97's Avatar
boomtruck97 is an unknown quantity at this point
and belts - the serpantine may be pretty cracked and worn. if not changed in a while get it.
clserratos
Nov 24, 2010 12:00 AM
Megarawdeal
Jul 25, 2010 03:16 PM
apross44
Mar 18, 2010 12:27 PM
97blazer617
Nov 17, 2009 08:31 PM
Blazerx85
Apr 11, 2007 07:28 PM
