Turn Popping/binding in 2wd
#21
+.15 degrees is already toe in, (too far). If they're both at +.15 degrees, your total toe is +.3 degrees. Maximum total toe should not exceed .1 degrees, in either direction. As far as how many degrees per rotation of the sleeve, I don't have a clue. You might start with 1/10 of a turn and measure it.
#22
My original plan was to try to turn each equal amounts to try to center my steering wheel, then adjust each a slight amount out, then have a alignment check done (free at the local sears).
#23
the toe in/out would need to be far more than .15 to make it 'pop' as you describe. it would wear the tires though. I would question the alignment shops work if it had an alignment and does as you describe. GM did a poor job of the steering geometry on these trucks, they will always scrub tires.
low tire pressure, ball joints, tie rod ends, control arm bushings, wheel bearing, cracked ring in outer CV, loose wheel...
#24
the popping is gone (greased the steering stops).. it's just the hopping to the side that I do not like, but the left tire is at ~.10 and the right at ~.14 which makes total toe ~.24... that would account for the hopping sideways at full lock... but the hunter alignment system shows that as being within specifications.... the only loose parts left are the lower control arm bushings. tie rods, ball joints, idler arm, pitman arm, upper control arm bushings, cvs, all in good condition.
I have never had an alignment done to the vehicle, only had it checked in july when it went in for inspection.
#26
I plan on getting a proper alignment done this spring.. but only after I get all the front end parts in 100% condition.
#28
I plan on doing a bit of t-bar crank to level out with rear, maybe 1/4"-3/4" as I think it's sagging to begin with. but will have it properly checked once it's on the alignment lift.
#30
oh yes, well aware... i've done plenty of research
